04-17-2016 10:50 AM
Hello
I have written an application in visual basic 6.0 which tests for the correct operation of a controller via USB.
I get the following error message
Unable to open Device
Ibsta= &H
8000iberr = 7
What I want to know is: -
What is the failure?
Is it to do with the routine of calls to the device?
Any help on this matter would be greatly appreciated
04-18-2016 10:56 AM
The iberr code points 488.2 going through an EDVR (0) system error. This error occurs when the interface or device name passed to ibfind of the interface index passed to ibdev cannot be accessed.
Below is more information on the error
EDVR (0)
Error Condition: Operating System error.
Description: EDVR is returned when the board or device name passed to ibfind, or the board index to ibdev, cannot be accessed. The global variable ibcntl contains an error code. This error occurs when you try to access a board or device that is not installed or configured properly.
Possible Cause: Often EDVR errors are caused when you misspell the board name. For example, you may type ”ibfind GPIB9” or “ibfind GPIBo” or “ibfind GPIB 0” instead of “ibfind GPIB0”.
Solutions:
There is further reading on this topic in the NI-488.2 Reference manual linked below on PDF page 98.
NI-488.2 User Manual for Windows
04-18-2016 11:01 AM
My bad,
I actually pointed towards an error that occurs when iberr = 0, and not iberr = 7.
The actual error that you are getting is ENEB (7). Below is more information on that.
ENEB (7)
Error Condition: Nonexistent GPIB board.
Description: ENEB occurs when no GPIB board exists at the I/O address specified in the configuration program. This problem happens when the board is not physically plugged into the system, the I/O address specified during configuration does not mach the actual board setting, or there is a system conflict with the base I/O address.
Solution:
This makes it seem like the system is having trouble finding or seeing the device. Do you have all the proper drivers for the controller installed? Does the device show up in device manager?
For future reference, the iberr value can be linked to the error description in the 488.2 user manual on PDF page 97. I have linked the pdf again below.
