03-12-2007 07:54 AM
03-12-2007 09:18 AM
Ok I reinstalled VISA and IVI compliance package 2.3 .
Now I can communicate with the scope while the IVI driver is det to NO SIMULATION mode.
On the CWIVIScope component I can set the ENABLE on and and can configure and can verify the confiuration ok as
when I click the configuration , it communicate with the instruments and say Configuration ok.
With the program Ni CWIViScope in the NI example folder I can configure ,
I can even change the vertical range by rotary dial on the program panel.
but whenever I tried to capture one channel ( 1 or 2 ) it gives a error
Run -time error '-30521(ffff88c7)':
(CHANNEL2)Timeout expired before operation complleted.[IVI Error Code: BFFF0015]
CWIviScope1.Channels(2).Read cwiviscopeWaveform
I tried to increase the timeout , no effect.
Whenever I click to the bug it repor problems with the following line
Any sugessions.
with best regards
Ray
03-13-2007 03:58 PM
03-14-2007 03:42 AM
