07-26-2022 06:33 PM
Hi, I am working on using EXCEL VBA for lab automation including controlling lab instrument (v/i/load); downloading screen capture etc.
In VBA reference, I included
The VBA doesn't recognize any viXXX command such as viOpenDefaultRM etc.
Question: Is this caused by visa32.dll not compatible with Excell 64 or other reasons? Any advise?
Thanks for your time and support!
BTW,
The VBA does work with the following syntax:
Dim ioMgr As VisaComLib.ResourceManager
Dim Equip As VisaComLib.FormattedIO488
Set ioMgr = New VisaComLib.ResourceManager
Set Equip = New VisaComLib.FormattedIO488
Set Equip.IO = ioMgr.Open("USB0::0x0699::0x0503::C010200::0::INSTR")
Equip.WriteString "*IDN?"
MsgBox Equip.ReadString
Equip.IO.Close
11-01-2022 04:54 AM
VISA 5.13 sounds very old. Is that NI VISA or the VISA installation from Keysight? Not sure about the Keysight versions but 5.13 would be definitely way pre 64-bit support for the NI versions. So either install a recent NI version of NI VISA or check with Keysight what you need to be able to use the driver from VBA from a 64-bit application.
