Mark,
I just had one more thought. You can set the MousePointer property of almost
everything on the from, but unfortunately the CWGraph object doesn't have
this property. You might try putting a frame on the form, and putting a
new CWGraph object in the frame. Then in the Form_Load procedure you could
assign:
Form1.MousePointer = 1
Frame1.MousePointer = 2 'or whatever you wanted
Then it looks like the mouse pointer will be changed whenever its over the
frame (which you might be able to size just slightly larger than your CWGraph),
but will revert to a normal pointer over the rest of the form.
Dave
Mark Downes wrote:
>Dave,> This will not work properly if the cursor is changed while over
the graph and th
en>moved quickly to another control in the form. It passes
over the exposed form before
>any>Form_MouseMove messages are generated.> Thanks for your help though.>>
Are there any more suggestions?>>Mark D.>>Dave Auyer wrote:>>> You might
try this (it seemed to work OK for updating a text box as to the>> mouse
position):>>>> set the mouse track mode when you load the form,>> CWGraph1.TrackMode
= cwGTrackAllEvents>>>> in event CWGraph1_MouseMove(), change the mouse cursor
to what you want it>> to be when the mouse is over the graph>>>> in event
Form_MouseMove(), change the mouse cursor to what you want it to>> be when
the mouse is over the rest of the form>>>> Hope this helps,>> Dave>>>> "MarkD"
wrote:>> >>I'm interested in using a custom cursor
while the mouse is over a CWGraph>object.>> One way that I've been told
I can do it is to use the windows messages>TrackMouseEvent>> and WM_MOUSEMOVE
to determine if the cursor is over the graph.> In order>> to use t
hese API,
I need to have the hWnd of the CWGraph object.> How can>> I get the hWnd
and is there a better way of determining if the cursor>is>> over the graph?>
