Measurement Studio for VB6
DAQmxRegisterEveryNSamplesEvent Error
I am a software engineer specializing in Korean measuring instruments.
I have a working app that uses VB6 with NIDAQmx.
NI driver(NI-DAQmx) 2022 Q3 version works normally, but the latest version (2025 Q1) does not run the application and the following error appears.
No starting point
The procedure entry point DAQmxRegisterEveryNSamplesEvent_VB6 could not be found in the DLL FS_Tester.exe.
So I'm currently using the old version of the driver, but if you know the cause and solution, I'd appreciate it.
Message 1 of 1
(223 Views)
