04-02-2008 07:37 AM
I want to write a large data set to two analog output channels of the 4461 DSA card simulteneously. What I have done is that I have used AIAOShardTimebaseAndTrig_DSA from the DOT NET examples as base and modified it for multiple analog output and analog input channels. (changed its SynTaskReader and SyncTaskWriter to incorporate multiple channel reads and writes)
Please find the attached image as the result of what I am getting. I have simply connected the AO0 to AI0 and AO1 to AI1
As one can see there are two issues with the graphs.
Please tell me what I am doing wrong. Following are the specifications
Samples to Write: 264130
Timing: continuous samples
Clock: DSA sample clock
The card is in slot 2 of the pxi chasis
Rest is all the same as is done in the example (like synchronizing slave and all)
Look forward to some wonderful learning,
Best Regards,
Alok Damle.
04-02-2008 11:42 AM
I forgot to mention that I am using VS 2005 and coding the same in C#. Also the scan rate is maximum that is 204.8KS/s
Alok
04-03-2008 05:40 PM
04-03-2008 05:48 PM
