08-16-2017 11:12 AM
This issue seems unlike other "unable to find module depency" topics in the forum.
I'm using Visual Studio 2010, Measurement Studio 2010 SP1. I'm trying to deploy a project built with the setup wizard. More precisely, I've been deploying it for a few versions now. It works fine on most computers, but I'm wondering if these warnings are the root of the problem a few users have reported (controls not displaying, timer running very slowly)
This warning appears three times when I build my project:
Unable to find module dependency with signature 'NIMesaDLL.6FE8CEDD_964F_47A2_8F23_5A607953B235'
Scrolling through the list of detected dependencies, I can't find anything matching this signature. I'm only using UI
controls in my application -- no data acquisition calls, for example.
I get the same warning if I create a blank project (no controls on the form, no code except what Visual Studio creates, but including the NI Windows Forms & User Interface Library as part of the project. No such warning if I don't include the NI Library.
a) Is it safe to simply ignore the warnings?
b) If not, how can I make them go away?
08-17-2017 03:16 PM
If you go to C:\Program Files (x86)\Common Files\Merge Modules do you see "NIMesaDLL.msm"? This is the merge module that the UI controls use.
This may also be a good document for you to reference for the dependencies for the UI library:
http://zone.ni.com/reference/en-XX/help/372636F-01/mstudiowebhelp/html/netmergemodules/
08-23-2017 06:16 PM
No, I don't see that file.
08-24-2017 04:37 PM
Does this warning occur on every single computer that you are deploying your project on? Do you have an installer to go along with you build?
