I'm not quite sure what you mean by the axis not being independent. One of the ScatterGraph's properties is the collection of Plots. You can create new ScatterPlots and specify their x and y axis, and their x and y data points. I modified the VB XYGraph example to graph independent plots. This example is installed by default to:
C:\Documents and Settings\All Users\Documents\National Instruments\MStudioVS2005\DotNET\Examples\UI\WindowsForms\Graph\XYGraph\VB
This example allows you to plot different shapes. Each time it changes the data in the plot, I changed it to instead create a new plot every time and add it to the collection of plots. So, in each function for plotting a shape there is a line that says:
xyPlot.PlotXY(dataX, dataY);
which I changed to:
Dim newPlot As NationalInstruments.UI.ScatterPlot = New NationalInstruments.UI.ScatterPlot(xyPlotXAxis, xyPlotYAxis)
newPlot.PlotXY(dataX, dataY)
xyDataScatterGraph.Plots.Add(newPlot)
To get it to do what I think you are wanting to do.
Let me know if you have any questions, or that's not quite what you are wanting to do.
Message Edited by KristenC on
03-28-2008 10:54 AM
Kristen
