WPF GaugeDouble RangeFill
Hi
I am trying out the GaugeDouble wpf control. For the winforms control there is a RangeFills property. Is there a similar property for the GaugeDouble wpf control?
Kind regards
/Axel
Message 1 of 9
(7,636 Views)
Accepted by topic author AxelHaraldsson
The short answer is that there is no direct feature equivalent to the RangeFills property in Windows Forms, but you can mimic the effect with careful use of some primitive types:
    <ni:GaugeDouble>
        <ni:GaugeDouble.TrackDecorations>
            <niPrimitives:RegionFigure ZIndex="-10"
                                       RelativeWidth="0.4"
                                       RelativeHeight="0.08"
                                       RelativeVerticalPosition="1.022"
                                       RelativeVerticalAlignment="Far"
                                       Fill="LimeGreen" />
        </ni:GaugeDouble.TrackDecorations>
    </ni:GaugeDouble>
The longer answer is that, for the first version of the WPF controls, we intentionally left many of the underlying primitive types with minimal documentation, as we may change them in the future. In the current implementation, we use RegionPanel and attached properties like RelativeHorizontalAlignment to perform the layout for many of our controls. Although these exact members may be removed in a later release, we do plan to provide equivalent functionality and stabilize the primitive API over time.
Besides that caveat, I hope you find this useful.
~ Paul H
Message 2 of 9
(7,625 Views)
Thank you for the answer. Just one more thing: my xaml file does not accept "niPrimitives:RegionFigure". What references/namespaces is required in my file? I am using version 13.0.45.242 of NationalInstruments.Controls
/Axel
Message 3 of 9
(7,614 Views)
Here are the XML namespaces for the WPF controls:
    xmlns:ni="http://schemas.ni.com/controls/2009/xaml/presentation"
    xmlns:niPrimitives="http://schemas.ni.com/controls/2009/xaml/presentation/primitives"
~ Paul H
Message 4 of 9
(7,606 Views)
what i have to do if i want the Fillrange from 4 to 8 for example ?
Message 5 of 9
(7,314 Views)
Try this :
Dim o AsNew NationalInstruments.Controls.Primitives.Regions.RegionFigure
o.ZIndex = -10
o.RelativeHeight = 0.08
o.RelativeVerticalPosition = 1.022
o.RelativeVerticalAlignment =RelativeAlignment.Far
o.Fill =Brushes.LimeGreen
o.RelativeHorizontalPosition = (LowerLimit - LowerRange) / (UpperRange - LowerRange)'start
o.RelativeWidth = (UpperLimit - LowerLimit) / (UpperRange - LowerRange)'length
g.TrackDecorations.Add(o)
Message 6 of 9
(7,305 Views)
Sorry for my poor english!
Where find i the RegionFigure in version 15.0.45.3898 of NationalInstruments.Controls?
I was looking for this in the NationalInstruments.Controls.Primitives in ObjectBrowser, but not containing this.
Or where is the problem?
(Visual Studio 2013 Community UPD 5, MeasurementStudio 2015 Standard, .NET4.5 WPF application)
Tamas
Message 7 of 9
(5,328 Views)
You are not missing anything: the "region" types from the initial release of the Measurement Studio WPF controls were replaced by "relative" types, to fix several layout performance issues.
To achieve the same effect in the latest version of Measurement Studio, you can use some of the new "relative" types:
    <ni:GaugeDouble>
            <niPrimitives:RelativeRadialScalePanel
                niPrimitives:RelativeRadialHostPanel.Edge="Inside"
                niPrimitives:RelativePanel.RelativeWidth="1.0"
                niPrimitives:RelativePanel.RelativeHeight="1.0"
                niPrimitives:RelativePanel.RelativeHorizontalPosition="0.5"
                niPrimitives:RelativePanel.RelativeHorizontalAlignment="Center"
                ArcSweep="{Binding ScaleArc, RelativeSource={RelativeSource AncestorType=ni:GaugeDouble}}"
                <niPrimitives:Baseline
                    RelativeLength="0.4"
                    Stroke="LimeGreen"
                    StrokeThickness="5"
                    StrokeEndLineCap="Flat"
                    StrokeStartLineCap="Flat"
            </niPrimitives:RelativeRadialScalePanel>
    </ni:GaugeDouble>
~ Paul H
Message 8 of 9
(5,312 Views)
Many thanks!!!! Work perfectly!
Tamas
Message 9 of 9
(5,306 Views)
