VoltageMeasurement example NIDMM C# error
I am trying to run the Voltage Measurement example and I am getting the following error:
Inheritance security rules violated while overriding member: 'NationalInstruments.ModularInstruments.NIDmm.NIDmm.Ivi.Dmm.IIviDmm.Configure(Ivi.Dmm.MeasurementFunction, Double, Double)'. Security accessibility of the overriding method must match the security accessibility of the method being overriden.
I have been testing the NISwitch and NIPower and it is only the NIDMM that causes this.
Can you help please?
Thanks.
(147 Views)
were you ever able to fix this issue? I'm running into the same issue.
Thank you
(72 Views)
