VS2012 setup and deployment issue with scatter graph
I have recently upgraded one of my programs from VS2008 to VS2012.  I also had Measurement Studio 2009 and upgraded to 2013.  Since Microsoft dropped their setup and deployment in VS2012, I am attempting to use Flexera Express to build a setup program.  My application contains a form that has a scatter graph control that needs to be deployed on Win7 and XP machines.  I attempted to force the compile to .NET framework 4.5, but that won't support XP.  I downgraded the .NET framework back down to 3.5.  I noticed that I had to change the NI references each time I changed the .NET framework.  I only had references to the NationalInstruments.UI, NationalInstruments.UI.WindowsForms, and NationalInstruments.Common.  When I build the setup it requires me to explicitly declare the redistributable packages.  So I selected the NI Measurement Studio Windows Forms Support package and it selects the Design-Time Support and User Interface Common Support automatically (dependencies I'm guessing).  But after I build this version of the setup and install it on a system, I get the following message when attempting to initialize the scatter graph control:
Could  not load file or assembly 'NationalInstruments.UI, Version 8.9.35.246, culture=neutral, PublicKeyToken=18cbae0f9955702a' or one of its dependencies.  The system cannot find the file specified.
Is there a redistributable package I'm missing?  I've tried to add in Base Components for running Measurement Studio, but get the same error.
I tried to use Wix, but ran out of patience trying to figure that one out.  Any help is greatly appreciated.
(5,710 Views)
Accepted by topic author msouza
In general, when deploying utilities from with Measurement Studio controls you should refer to this documentation for the necessary dependencies for merge modules:
http://digital.ni.com/public.nsf/allkb/6677098983C36F9086256CFE007F457A?OpenDocument
Ian M.
(5,700 Views)
