VISA32.DLL of NI can't support GPIB interface
HI:
I use the visa32.dll development tool
Declare Function viOpenDefaultRM Lib "VISA32.DLL" (ByRef sesn As Integer) As Integer
Declare Function viGetDefaultRM Lib "VISA32.DLL" Alias "#128" (ByRef sesn As Integer) As Integer
I find that if I use the "Keysight" driver. I can control the "GPIB0::20::INSTR" address of the instrument. But I use the "NI" driver. I will not be able to control the "GPIB0::20::INSTR" address of the instrument.
Why is this?
Are two visa32.dlls different?
I find the sizes of two visa32.dlls are different.
(2,648 Views)
Hi
I have the same problem. Did you ever find a solution for this?
(2,487 Views)
Use NI VISA or Agilent/Keysight VISA. Not both.
(2,478 Views)
Ok, so it all happned when I updated to LabView 2019. The visa32.dll in the SysWOW64 folder updated to something that does not work with my old VB6 visa32.bas module. So is there another visa32.dll somewhere in a Keysight version?
(2,475 Views)
You will have to find out how to use the Keysight VISA and not the NI VISA.
(2,473 Views)
Accepted by topic author xiaochouyu
The problem has been solved If two drivers are hidden at the same time. Then one driver uses "GPIB0" and the other uses "GPIB1"
(2,418 Views)
