09-01-2017 11:23 AM
I am not sure where this post should be since I am rather confused about the NI software products. I don't use Labview and I don't use Measurement Studio.
I am using NI-DAQmx with a custom software application created in Visual Studio 2015 using C# (.net 4.5). I've installed the drivers and NI development tools on the same PC as VS and everything works fine. When I install the application on another PC that doesn't have VS it doesn't work because I get an error that the DLLs aren't loading. I have included the two DLL files NationalInstruments.DAQmx.dll and NationalInstruments.Common.dll in the project and they get copied to the target PC. What am I missing?
Does NI require a special, separate installation of the DLLs so they get registered? If so, what installer should I be using so I don't install all of the development stuff on a target PC?
What about drivers? I am using the 9217 temperature module and the 9171 single slot USB chassis.
Thanks.
09-05-2017 01:21 PM
Hi jmp80128,
Could you please give us some more information about how you are building the project and how you are including the DLL's in the build?
Also, please provide a screenshot of the error you are getting. Or more information about the error.
-Mitchell | NI
09-05-2017 02:22 PM
In VS I added the two DLLs to project just like a .cs file. I also added a reference entry for them so the "using" statement in the source files work.
I have a second PC with VS on it but I have not installed the NI DAQmx software or drivers. I copied the entire project file to the second PC. The project included the two DLLs. When I ran the project an exception was thrown on the step where I configure the task. Unfortunately I don't have a screen shot of the error. The error looked like something was loaded.
If I run the installer in NIDAQ1710f0 everything starts to work. I could run that installer on all of the target PCs that will be running my software. However, I'd sure like to know what's causing this. I'm pretty sure I am missing the USB driver but it looks like the main DLLs aren't being recognized.
Speaking of drivers, which is the driver specific to the 9171 chassis?
Jim
09-06-2017 10:06 AM
What error are you getting? Please provide more information about the exception or errors that you are seeing.
Screenshots would be helpful.
11-26-2018 08:56 PM
I am in the same situation: developing an application in C#.
Bringing in these two files:
along in my installer seems to work,
However what I am puzzled about is; is it legal and is it the proper way to do it?
When trying to look-up the answer I came across pages from National Instruments'website stating a copyright note should be added somewhere.
Sorry I did not recorded the exact URL of the page I am referring to,
It' is also highly probable that I misunderstood it.
Thank you!
12-01-2018 10:11 PM
I came across this other post in a more appropriate board for such question, and will assume it applies to my case! 🙂
