Purpose of Channel Maximum and Minimum value
I am working with .NET Class Libraries to build a tool which interfaces with a force bridge load cell. When using the example software for force bridge sampling, there is a section in the top left which asks for a minimum and maximum channel value. Adjusting the values does not seem to change the sensor output whatsoever. What is the purpose of these items? I can't seem to find anything online either.
(439 Views)
Those maximum and minimum values help the driver determine the appropriate channel range (input/output) to accommodate the min/max values.
This is useful for DAQ with multiple ranges.
Santhosh
Soliton Technologies
(428 Views)
