10-05-2018 04:58 AM
I am using a C# application to capture 4 to 20 mA from a sensor, previously I successfully used a cDAQ 9208 card, I have now switched to PXI 4302 card with 4302C terminal Block.
The application creates a virtual channel using the following code:
myTask.AIChannels.CreateCurrentChannel(physicalChannelComboBox.Text,"",
(AITerminalConfiguration)(-1), Convert.ToDouble(minimumValueNumeric.Value),
Convert.ToDouble(maximumValueNumeric.Value), AICurrentUnits.Amps);
This causes an exception, stating 'CurrentShuntResistance Requested Value 249.0 Possible Values 5.0'
However the call is for an internal shunt resistor, and you do not need to specify a value; if I specify a value I get an error complaining about shunt resistor location being incorrect, it expects an internal shunt resistor.
Is this the correct command for a 4302 card to read input current? Could this be a configuration issue?
I have used an NI example application, 'ContAcq0_20mACurrentSamples...', which gives the same error as my code.
Error messages are attached.
Regards. Dave.
10-09-2018 04:56 AM
I have tried to set the property CurrentShuntLacation and CurrentShuntResistance after the call to CreatCurrentChannel:
// set shunt resistor property
myTask.AIChannels.All.CurrentShuntLocation = AICurrentShuntLocation.Internal;
myTask.AIChannels.All.CurrentShuntResistance = 5;
This had no effect, I still get the error that the requested value for shunt resistance is 249.0, which appears to be the default value for an "External" virtual channel.
I can use MAX to create a Task and read current from the PXIe4302 card, and I can use a cDAQ 9208 card with the above command.
Regards
Dave
