OPC with NI
Hello there
I'm new to OPC. I have 2 questions:
  1. I would like my C# based application to have OPC client capabilities. I had integrated NationalInstruments.Net dll, and it worked. The thing is that the test was done with a dll I have taken from the trial version of Measurement Studio, and now it is expired. The question is, if I purchase a license for Measurement studio, would I will be able to add the dll to my systems, and it will work? Is there any limitation for this kind of usage?
  2. For another application, I would like to integrate OPC server using. NationalInstruments.Net dl. Are there any code examples? I would like to get assistance
(2,262 Views)
1. Yes, you will need to buy Multisim for your application.
In here you can check the benefits from each edition:
http://www.ni.com/en-us/shop/electronic-test-instrumentation/application-software-for-electronic-tes...
2. Here is a tutorial that explains through examples how to achieve these communications: http://www.ni.com/tutorial/3259/en/
(2,244 Views)
Thanks for the reply
One thing I did not get an answer to, is how can I add OPC server capabilities to my device using NI?
Is it possible?
Koobi
(2,237 Views)
