01-24-2006 12:18 PM
01-24-2006 01:07 PM
I strongly suggest that you do not use the "Copy Local" setting in this manner. It will inevitably lead to problems, as discussed in this forum thread and this forum thread. See the Knowledge Base article "Plots, Axes, and Cursors Disapperaing from Graph Control" for more info. In addition to these problems, it is not a reliable method for deployment, as you have already seen.
If you are using 3D styles and you are using xcopy deployment, there are additional files that you will need to deploy. Namely, you need the NationalInstruments.UI.Styles3D.dll assembly and its dependencies, which are mesa.dll, msvcr71.dll, and msvcp71.dll. For more information, see the "Measurement Studio .NET XCOPY Deployment Files" topic in the Measurement Studio Reference.
- Elton
