Measurment Studio 7.0 Data Socket Connect issue
I am using VB .NET 2003 with Measurment Studio 7.0 and I have an issue with the Data Socket Connect command.  I have several points of interest that I need to capture using a DDCS connection.  I iterate through them in a loop.  At various points the connect fails to return to the calling code.  I have stepped through this several times and it fails at different points ever time.  It is not consistent.  I have tried putting in Sleep commands to slow the connects down, but this is still not reliable.  Also, I noted in several of the other posts that in order to clear the cache of these connects, I need to close Visual Studio all together.  Here is an example of how my code looks:
While Not myURL.EOF
Loop
Message 1 of 1
(2,678 Views)
