08-08-2017 07:35 AM
08-08-2017 09:00 PM
Hi,you can install NI DAQmx. There are many classical C and .net examples .
Path: ...\NI-DAQ\Examples\...
Hope it can help you
08-08-2017 09:23 PM
Thanks so much. It is very helpful for me. 🙂
08-09-2017 01:10 AM
Hey, I have just installed both Visual Studio 2012 and MStudioVS2010, I also can find some instructed projects in my computer, just as /National Instruments/MStudioVS2010/DotNet/Examples/Analysis,Application.etc. I think the installation is completed. But actually I cannot find any class libary and application templates about Measurement Studio in the panel when I create a new Visual Studio 2012 project. Is any thing mistake when I do it? For I could like create a project which could control one NI card in my PC. Thanks so much.
08-09-2017 08:37 PM
Frist,you can run the examples ,see its effect,learn its struct.
Usually it includes the head file,like NIDAQmx.h ,which can find it in our compter.
You just need call it.
The file's path is...\NI-DAQ\DAQmx ANSI C Dev\include\...
08-16-2017 06:58 AM - edited 08-16-2017 07:03 AM
Hello Frank,
Make sure that you have added references to the
NationalInstruments.Common
and
NationalInstruments.DAQmx
dll files in your project. Mine are located in:
C:\Program Files (x86)\National Instruments\MeasurementStudioVS2012\DotNET\Assemblies\Current\
You can then add them to your list of directives:
using NationalInstruments.DAQmx;
using NationalInstruments;
Hope that helps.
Tim
