Ivi.Visa.Interop missing
Hi vchandra,
It sounds like this is an issue with the installation of NI-VISA being faulty. Have you tried uninstalling and reinstalling, or force reinstalling NI-VISA? Is this the first time you installed NI-VISA on this computer?
Also, this thread is 4 years old so you may want to post your question in a new thread so that it gets for visibility in the community.
Adena L.
Technical Support Engineer
Message 11 of 12
(1,580 Views)
"Failed to install command set '34401 Digital Multimeters'. Could not load file or assembly 'Ivi.Visa.Interop, Version=3.0.0.0, Culture=neutral, PublicKeyToken=a128c98f1d7717c1' or one of its dependencies. The system cannot find the file specified."
I get the above error when I try to use Agilent 34401A digital multimeter with the National Instrument GPIB-USB-HS adaptor combination. This is happening when I try to install the command sets for Agilent 34401A using Keysight command expert.
More info:-
This is what exactly I do in keysight command expert
New Instrument >> Connect to a real Instrument >> Next >> Selected ESG -D4000B - B.03.86 - US38440605 >> Next >> Selected ESG Signal Generators >> Next >>Add to my instrument >> Getting an error after progress window..
Message 12 of 12
(543 Views)
