12-06-2006 07:20 AM
I am using windows XP pro, Visual Studio 2005, and MS 8.0.1 and trying to install the help files, but I get this error every time. When I go to use the F1 function of help for the classes in MS it comes up with "Information not found" along with a few steps to get the info to pop up, but no luck there either.
Has anyone received this message before? Or, is there a certain sequence to installing everything?
Mtonsager
12-07-2006 11:55 AM
12-08-2006 08:15 AM
12-11-2006 06:38 AM
Thanks for helping out.
I guess I only have the basic service so I am only able to use the discussion forums. I am wondering if needed to have the msdn Library documentation installed before the MS 8.0.1 software? I wonder if I should uninstall MS 801, msdn library, and VS 2005, then reinstall them? What do you recommend being installed before installing MS 801?
Thanks again,
Mtonsager
12-12-2006 12:19 PM
12-12-2006 01:51 PM
Sure, you can email me. My email is in my profile.
Mtonsager
03-13-2008 01:51 PM
I am having this same issue, but I didn't see a resolution since it was e-mailed to the requestor. I am also having bad problems trying to install 8.0.1 both on the Measurement Studio side and Driver CD side.
I have an open support request for this (which might be in my profile), but they haven' t got back with me on a solution yet. Could you also "e-mail me the solution"?
-Matt
