Input analog signal in NI USB-6008 Measure Frequency
Hi All~
I have download the DAQmx 9.7 dirver and installed it, The example of "Measure Frequency" is for SCXI1126 device, I want to use NI 6008/6009 to measure frequency, How can I do ?
Tips: If i run the example of "Measure Frequency" is for SCXI1126 device,
The error:
Selected physical channel does not support the measurement type required by the virtual channel you are creating.
Create a channel of a measurement type that is supported by the physical channel, or select a physical channel that supports the measurement type.
Property: NationalInstruments.DAQmx.AIChannel.MeasurementType
Requested Value: NationalInstruments.DAQmx.AIMeasurementType.Frequency
You Can Select: NationalInstruments.DAQmx.AIMeasurementType.Current, NationalInstruments.DAQmx.AIMeasurementType.Resistance, NationalInstruments.DAQmx.AIMeasurementType.StrainGage, NationalInstruments.DAQmx.AIMeasurementType.BuiltInTemperatureSensor, NationalInstruments.DAQmx.AIMeasurementType.Rtd, NationalInstruments.DAQmx.AIMeasurementType.Thermistor, NationalInstruments.DAQmx.AIMeasurementType.Thermocouple, NationalInstruments.DAQmx.AIMeasurementType.Voltage, NationalInstruments.DAQmx.AIMeasurementType.VoltageCustomWithExcitation
Task Name: _unnamedTask<0>
Status Code: -200431
Message 1 of 1
(5,469 Views)
