02-06-2018 12:36 PM
I would like to display data in a 3D graph in my NI WPF application. It is my understanding that there is not a WPF 3D graph I can use out of the Visual Studio Toolbox that I can just drop into the designer (i.e. DigitalGraph, Graph, IntensityGraph, etc.). After doing some research I learned that NI has a ActiveX ComponentWorks 3D graph that can be added into WinForm applications fairly easily. However, I know that it is possible to host ActiveX controls in WPF applications so that is what I have been trying to do. So far I have not been successful.
Before I began writing the code shown below I found some NI WinForm sample applications online to figure out what references I needed to use the 3D graph and how to interact with it. I found that in order to use the CWGraph3D Control the following references are needed (and maybe some other references from the System namespace I am forgetting).
I figured that if I could add these references to my NI WPF application, then I could add the ActiveX 3D graph to my view programmatically. To get a copy of these references, I created a new NI WinForm application, added the CWGraph3D control to the Toolbox, added the graph to the application's form, and built the solution. Doing so produced 2 DLL's of interest underneath the project's bin directory, specifically AxInterop.CW3DGraphLib.dll and Interop.CW3DGraphLib.dll.
I copied these assemblies to my NI WPF application's lib directory and added references to them from the Visual Studio Solution Explorer. From here I was able to begin writing code to host the ActiveX control inside my WPF application (intellisense was even working with it).
The XAML view I am attempting to host the ActiveX control in contains a stack panel.
<StackPanel x:Name="RaControlContainer"> <TextBlock x:Name="RaTitle" FontSize="20"/> </StackPanel>
Next is the code behind for given XAML view.
private AxCWGraph3D _graph; public RaView() { InitializeComponent(); Loaded += OnLoaded; } private void OnLoaded(object sender, RoutedEventArgs routedEventArgs) { var host = new WindowsFormsHost(); _graph = new AxCWGraph3D(); host.Child = _graph; RaControlContainer.Children.Add(host); }
I can build my solution without error and the WPF application runs fine as long as I don't attempt to activate the RaView (done with a button click). When I attempt to activate the RaView, the following exception is thrown...
An unhandled exception of type 'System.IO.FileNotFoundException' occurred in WindowsBase.dll Additional information: Could not load file or assembly 'Interop.CW3DGraphLib, Version=1.6.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
I haven't been able to figure out why this exception is being thrown. I am a little bit baffled at this error because I know the Interop.CW3DGraphLib.dll exists in the directory where it is being referenced from. I would like to mention that this exception is thrown after the RaView() constructor is called and before the OnLoaded event handler is executed.
I am not sure what the problem is here, any suggestions/help is appreciated!
02-06-2018 05:37 PM
Showing data in my application in a 3D graph is no longer required. Please disregard!
06-15-2021 12:14 PM
Someone please regard, because I have the same question.
Same situation except I want a
private void UserControl_Loaded(object sender, RoutedEventArgs e)
// Create the interop host control.
System.Windows.Forms.Integration.WindowsFormsHost host =
new System.Windows.Forms.Integration.WindowsFormsHost();
CW3DGraphLib.CWGraph3D pc3d = new CW3DGraphLib.CWGraph3D();
host.Child = pc3d;
this.GraphGrid.Children.Add(host);
The error says that host.Child can't assign this type because it needs explicitly cast, but can't seem to find a type to cast it to.
