Hi Alavu,
NI TDM (Technical Data Management) file format is a structured, search-ready format that utilizes XML to manage a wide range of attributes associated with each data file. The TDM format is designed to capture and manage all the important information surrounding a measurement or simulation, assuring that the data is self explanatory, reusable, and requires no additional explanation to recreate the conditions in which it was captured.
The TDM file format specifies that descriptive information such as comments, units, and channel names are saved in a header file with the extension TDM, while the measurement, simulation or analysis results are saved in one or more binary file(s). The TDM and binary files are linked through references that are created automatically when using the LabWindows/CVI DIAdem Connectivity Library, LabVIEW Data Storage VIs, or programmatically when using the TDM Header Writer C API.
I have included a few links below that discuss TDM in more depth. In order to leverage the TDM file format in Visual studio, you will need to utilize the TDM C-DLL that is linked at the bottom of the first page listed below.
