05-09-2016 01:06 PM
I have a slider in WPF/C#
<ni:SliderDouble Height="60" Name="updateRate" ValueChanged="OnUpdateRateValueChanged" Range="0.05,1" Value="0.05" />
When application is running user can change min or max value of the range by clicking on the tick lable and editing the value.
Need a way to prevent/protect, make it not editable.
Thank you
Yuri
05-09-2016 01:19 PM
Scale range editing is controlled by the InteractionMode
property on the slider. To disable EditRange
, you can assign a different set of flag values, such as InteractionMode="ArrowKeys,Drag,Snap,ScrollWheel"
05-09-2016 01:23 PM
Thanks! Working!
