10-14-2015 03:19 PM
I am using CWIMAQViewer on a Windows Form (VS2008) to display gray scale images. I want to be able to change the size of the CWIMAQViewer at runtime. Is it possible to do this?
10-15-2015 01:49 PM
Hi aoslo,
I was able to find a document regarding your question which I've linked below.
http://www.ni.com/pdf/manuals/371257b.pdf
I would also check the NI Vision for Visual Baisc Reference Help which can be found C:\Program Files (x86)\National Instruments\Vision\Help\cwimaq.chm (this may be slightly varied if there was a custom installation).
I hope this helps!
- Kale
