How can I configure EOS character in VB.net + measurement studio ?
Hi all,
I would like to control Oxford temperature controller ITC503 via GPIB with VB.net and measurement studio.
The equipment requires that sent commands are terminated by a Carriage Return (CR) and responses
from the equipment are also terminated by CR.
I could set or change parameters of the equipment correctly by the code gpib.Write("command" & vbCr).
However, if I try to get responses by sending the code gpib.ReadString(), it always falls into timeout.
I guess this is because the EOS is not correctly configured.
I have already succeeded in accepting responses in MAX by setting EOS bite to 13.
I would be grateful if someone knows how to set EOS character in VB.net + measurement studio.
Thank you.
(4,658 Views)
Hi muramasa,
You can set the EOS to CR by using the viSetAttribute function and setting VI_ATTR_TERMCHAR to 0xD.
Please let me know if this helps.
(4,612 Views)
Hi, Kitajima-san,
Thank you very much.
I could settle the problem by adding following codes.
gpib.EndOfStringCharacter = 13
gpib.EndOfStringComparison = 0
gpib.SetEndOnWrite = False
gpib.TerminateReadOnEndOfString = True
gpib.SetEndOnEndOfString = False
muramasa
(4,598 Views)
