09-22-2017 11:18 AM
I am trying to get the temperature from a thermocouple and display it on my main window. It works perfectly on my computer. The temperature updates every two seconds as it is supposed to. I had previously posted a question about required DLLs for this to work on the lab computers which do not have NI software installed. I was told I needed to install the NIDaq Runtime engine. I installed that but still got the error:
"System.IO.FileLoadException: A procedure imported by 'NationalInstruments.DAQmx.dll' could not be loaded."
The stack trace takes it back to the constructor where I call the "Watch Temperature" method which does the following.
try { TempScanner = new Thermocouple(); TempWorker = new BackgroundWorker(); TempWorker.WorkerReportsProgress = true; TempWorker.WorkerSupportsCancellation = true; TempWorker.DoWork += (s, e) => { TempScanner.TempWorker = TempWorker; TempScanner.MonitorTemp(ref watchTemp); }; TempWorker.ProgressChanged += (s, e) => { var t = e.UserState as Temperature; this.Temperature = t.Temp; }; TempWorker.RunWorkerCompleted += (s, e) => { TempWorker = null; TempScanner = null; }; TempWorker.RunWorkerAsync(); }
The critical parts of the thermocouple class are shown below.
public Thermocouple() { //These are the default values. SecondsDelay = 2; MinimumTemp = -70; MaximumTemp = 200; List<string> chnls = GetPhysicalChannels(); PhysicalChannelName = chnls[0]; string[] ary = chnls[0].Split('/'); AssignedChannelName = ary[0]; ThermocoupleType = AIThermocoupleType.J; tempChannel = tempTask.AIChannels.CreateThermocoupleChannel( PhysicalChannelName, AssignedChannelName, MinimumTemp, MaximumTemp, ThermocoupleType, AITemperatureUnits.DegreesC); tempReader = new AnalogSingleChannelReader(tempTask.Stream); } public void MonitorTemp(ref bool watchTemp) { while (watchTemp) { if (!TempWorker.CancellationPending) { Temperature t = new Temperature(); t.Temp = GetTemp(); TempWorker.ReportProgress(100, t); t = null; Thread.Sleep(milliseconds); } else { tempReader = null; tempChannel = null; tempTask = null; } }; }
The runtime engine I installed was NIDAQ1410f1Runtime.
As you can see it is not all that complex. There must be a simple solution to this problem.
Thank you
09-25-2017 12:53 PM
What version of the DAQmx do you have on the working computer? It sounds like the development computer has a version newer than 14.1, and you just need a newer version of the runtime.
If it turns out to be a version conflict, you can download the latest version of the runtime here:
NI-DAQmx Runtime 17.1.0
http://www.ni.com/download/ni-daqmx-run-time-engine-17.1/6838/en/
