Digital I/O read write c#
Hi All,
I am developing a C# program which can communicate the device through Digital I/O.
In my PC I have a Digital I/O card.
After I made the write code base on the DAQmx example, the code doesn't give back error, but I can't see anything in the NI IO Trace. (I've started capturing...)
The example program does the same issue.
I don't know what the problem is. Nevertheless, If I push the start button on the test panel I can see the captured communication lines. Smiley Sad
Please help me whether the example code wrong or the NI IO Trace.
The example source code as below or in the attachement:
private void writeButton_Click(object sender, System.EventArgs e)
Cursor.Current = Cursors.WaitCursor;
try
using (Task digitalWriteTask = new Task())
// Create an Digital Output channel and name it.
digitalWriteTask.DOChannels.CreateChannel(physicalChannelComboBox.Text, "port2",
ChannelLineGrouping.OneChannelForAllLines);
// Write digital port data. WriteDigitalSingChanSingSampPort writes a single sample
// of digital data on demand, so no timeout is necessary.
DigitalSingleChannelWriter writer = new DigitalSingleChannelWriter(digitalWriteTask.Stream);
writer.WriteSingleSamplePort(true, (UInt32)dataToWriteNumericUpDown.Value);
catch (Exception ex)
MessageBox.Show(ex.Message);
finally
Cursor.Current = Cursors.Default;
Message 1 of 1
(3,629 Views)
