I have an VB.Net application where I use the cDAQ-9184 and cDAQ-9185 with some Analogue Input and Digital Output modules (NI 9476 and NI9205).
In this application it may happen, that the Ethernet connection to the chassis gets lost. In that case all digital outputs that are set to "High" should switch back to "Low". In the cDAQ-9185 that happens, but with the same modules and the same software the outputs on the cDAQ-9184 remain "High".
Is this a difference in the chassis or ist it something that could be modified with some settings?
Thanks in advance
Axel
