03-18-2008 10:11 AM
03-19-2008 05:06 PM
Hi Tyzack,
I am assuming that you are using a .NET language while experiencing this problem. Have you tried to use the example programs that are installed with DAQmx, if not the are located at:
C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples
If you have, and you are still getting this same issue, can you ensure that the device is correctly recognized in Measurement and Automation Explorer (MAX) and can you try to create a task in MAX, and see if you get the same issue (ie no problem with your E-series, but a freeze with the S-series). If you do running this problem, there may be a problem with your hardware. Let me know the outcome of these tests and we can continue to trouble shoot this issue.
Have a great evening
Chris_K
