NationalInstruments.Common.dll is fully backwards-compatible, so use the latest version ("19.1.40.49152", in this case). The latest installed version should be used automatically. (If you are using "xcopy deployment", you may need to add an assembly redirect to your application manifest to get the correct behavior on a target machine.)
