Changing the cDAQ9138/9 "USER1" LED status using C#/DAQmx
I need to be able to change the status of the USER1 LED on a cDAQ9139 chassis from my VS2010 C# application code. Can anyone point me in the direction of the DAQmx class/property/method I need to use?
Malcolm Sharp
(5,581 Views)
Hi Malcolm,
Taking a look into this it looks like unfortunately the USER1 led is only available for access from the Real-time operating systems. There is no access to it available from the DAQmx driver, when running windows on the cdaq.
Best Regards,
(5,540 Views)
Accepted by topic author MalcolmS
Thanks for the answer. I guess I'll have to come up with some other method of indicating the operating status when using the cDAQ9138 as a 'headless' system!
Malcolm Sharp
(5,513 Views)
