02-13-2006 07:00 PM
02-14-2006 06:17 PM
You are correct when you state that the two ways to program with Traditional NI-DAQ in Visual Studio .NET are through either the CWDAQ ActiveX control, or by making DLL calls to the Traditional DAQ driver. To make a call to a specific function, like the AI_Change_Parameter function, you will need to use the second method. For information about how to do this check out the following KB:
KB 3ELB5OTY: How Can I Make DLL Calls to Traditional-DAQ or DAQmx Base Functions in my .NET Program?02-14-2006 06:34 PM
02-15-2006 02:21 PM
11-23-2018 01:43 PM
All,
I'm using Windows 10 and I just installed the NI CompactRIO Device Drivers.
I'm looking for a way to write a program to read data from a cRIO-9074 controller. I realized that the only way to do that is using the old CWDAQ ActiveX controls or NI-DAQ API. However, I can't find the CWDAQ ActiveX controls in the list of COM Components of my Visual Studio 2017 after installing the the NI CompactRIO Device Drivers.
Why I can't find the CWDAQ ActiveX controls?
Is there a way to overcome this issue?
