09-28-2018 08:41 AM
Hi Everyone,
I’m a new LabView user and my LabView 2013 level is quite low and I’m looking for help. I created some simple software to control my power supply Agilent E3631A. So far I can set up output voltage for all 3 channels and monitoring voltage and current as well.
I want to sweep output voltage from 0V to 20V, using for example 20 points and obtain the current both in a graph and in a table. I spent a few hours analyzing various examples but I could not imagine anything.
Thanks for your time and effort
Artur
10-02-2018 02:03 PM
You need to supply all the SubVI's of your LabVIEW code, if not, one is not able to run and test what you are doing.
Pamela Gómez
Applications Engineering
www.ni.com/support
