Measure
Pressure transducer electrical termination
Hi all,
We are now in a position to choose the electrical termination of a pressure transducer. With this, we will be using NI 9208 (with Spring terminal)
My question: Which of the transducer's electrical termination attached may be best with regard to noise immunity, and also compatible with the module spring terminal?
Thanks.
(4,666 Views)
Accepted by topic author Cowboy12
So, it turned out that there is no difference with regard to noise immunity. Any of them could work with the spring terminal. We might just need to purchase the correct mating connector and attach wire to it.
(4,626 Views)
