06-27-2013 12:38 PM
I'm trying to make something similar to a moving average, but I want it to average every 10 data points instead of continually moving. I'm not exactly sure what this would be called, part of the reason I'm a bit confused on what to do. I've seen several moving average functions, but again that is not what is needed. I have a very large data collection and wanted to get it to a more manageable set of data. The data is coming in the form of ones and zeros. Any guidance on this matter would be appreciated.
Solved! Go to Solution.
06-28-2013 03:57 PM
You can review this forum post which deals with a similar requirement that you have.
Regards
07-08-2013 11:26 AM
Arham,
Thank you for your assitance. It took me a little while to test to make sure it was what I needed. It worked well.
Thanks again.
ssmcd
07-09-2013 11:30 AM
You're welcome. Good luck with your application!
Regards
