Hello, I just have to measure a 2.5Vdc (output of a hall effect sensor). With a simple voltmeter, as a Agilent 34401A, I can measure eg 2.5162V with a great stability, the last digit doesn't move. With the NI6220, it is completely unstable, the voltage is between 2.47V and 2.55V (a variation of 80mV). Do you have any suggestions to improve this measurment to get a good stability, in fact, how can I ignore the noise on this dc voltage, as the HP34401A or any simple multimeter is able to do it?
Thank you for your help.
