Measure
Keithley 2450 – Can’t read Voltage and Current in one SCPI query (firmware 1.7.3c)
Hi everyone,
I’m using a Keithley 2450 SourceMeter (firmware 1.7.3c) and controlling it remotely via SCPI commands (through VISA).
My goal is to source a current and acquire both voltage and current in a single read operation to improve sampling speed.
However, I’ve run into a problem:
*RST :SOUR:FUNC CURR :SOUR:CURR 0.01 :SENS:FUNC "VOLT" :FORM:ELEM VOLT,CURR :OUTP ON :READ?
At the :FORM:ELEM VOLT,CURR line, the instrument throws
ERROR -113: "Undefined header",
and as a result, :READ? only returns one measurement (depending on the last selected sense function).
When I use two separate queries like this:
:SENS:FUNC "VOLT"; :READ?; :SENS:FUNC "CURR"; :READ?;
…it works correctly, but it slows the acquisition by about 2.5× — defeating the purpose of simultaneous measurement.
I also tried:
:SENS:FUNC "VOLT:DC","CURR:DC" → ERROR -1129 ("Command needs 1 parameter") :SYST:LANG SCPI2400 → ERROR -113 :READ?; :FETCH? → two identical (current-only) results
So it seems that on firmware 1.7.3c, the 2450 might not support multiple sense functions in one command — or perhaps I’m missing the correct syntax.
My question:
Has anyone managed to configure the 2450 to source current and measure both V and I in a single SCPI query?
If yes, could you please share the correct command sequence or a working example?
It would also be helpful to know if this behavior differs in later firmware versions.
Thanks in advance for any insights or test feedback!
Best regards
(367 Views)
Please check the instrument manual if that is even possible, I bet it may be because it has only one ADC that mux between the current sense and voltage sense modes and hence you can read only one at a time and you lose performance due to the switching alternating measurements.
I recommend reaching out to Keithley tech support to check if the hardware and firmware allows one to simultaneously measure both voltage and current.
Santhosh
Soliton Technologies
(331 Views)
