Mass Compilers
AF user group meeting 05/12/16
What will the tutorial be, any slides available?
(9,659 Views)
I just published some slides in the Documents section. I'll put the sample code up there as soon as I can get access to it (technical difficulties). See you later!
(8,795 Views)
Sample code uploaded!
(8,795 Views)
mgi has a good write up on AF:
http://www.mooregoodideas.com/actor-framework-basics-part-1-the-background/
Also here is a link to the Actor Monitor Add-on (by MGI as well), that was mentioned at the end of the group meeting.  It shows you all the actors and gives you a way of stoping them if your stop isn't working right.
https://decibel.ni.com/content/servlet/JiveServlet/download/57757-80310/mgi_lib_monitored_actor-0.1....
(8,795 Views)
I have created the CLD practice ATM exam in Actor Framework
If ppl think it's of value to spend 20-30 min looking at this at the next meeting, I could bring my laptop.
p.s. of course, this being my frist project in AF - don't expect perfection, but I would gladely use some pointers.
I have also used the monitor actor add-on to monitor my actors properly shutting down.
(8,795 Views)
That would be great! Bring it and we can certainly fit it on the first part of the meeting and perhaps give some pointers.
(8,795 Views)
