01-06-2010 09:20 AM
Hi
I am using pci 1411 card . I have installed ni vision . I want to control snapping operation by any key of keybourd.for that
I require snap.vi. according to manual it should present in block called image aquisition. Ihave checked path(fuctions-ni measurments-vision) but i am not able to find it .Help me to find out it.
01-06-2010 02:52 PM
01-19-2010 04:07 AM
i reinstalled the ni imaq again.but stil not able to find out niimq snap vi.
it is not showing image aquisition option in fuction.
01-19-2010 04:24 AM
01-19-2010 07:20 AM
01-19-2010 07:24 AM
02-03-2010 09:38 PM
my labview version is 7.1
and ni vision version is 7
02-03-2010 09:46 PM
beside imq vision i have to do one more job the job is i have to take output from two optocoupler one is placed horizontal and one is vertical.the output of optocoupler is 3.2 v for high and nearly 1.2 v for low.i am using pci6014 daq card.labview version 7.1
can you tell me how i should start with this particular job.
02-04-2010 01:50 AM
Hi Quary.
You have LabVIEW and you have the Vision Development Module but what you are missing is the driver to get your images from your camera. This driver is included in the Vision Acquisition Software. You should find it together with your framegrabber card from NI. If you don't use NI hardware you need to buy the Vision Acquisition Software.
Here is a compatibility list for the driver (IMAQ for framegrabber-connected cams, IMAQdx for IEEE1394 and GigE)
http://digital.ni.com/public.nsf/allkb/6B55FF09D1FBD3108625719600650B7C?OpenDocument
To answer your DAQ question I suggest that you open a new thread in the DAQ forum.
David
