Machine Vision
where can I get a PCI-1424 frame grabber
Dear,
I recently bought a imager sensor that would require PCI-1424 frame grabber  to build up a camera. However I found that NI doesn't sell PCI-1424 anymore. Does anyone know where I can still get a PCI-1424? Or if not, which type of frame grabber can be a replacement of PCI-1424.
The board I have now has a 100-pin connector that is said to be directly interface with PCI-1424.
kind regards,
(3,729 Views)
You need RS-422 (LVDS) to Camera link converter. Then you can use NI PCIe-1473R.
I did quick search on the web and fond http://www.vividengineering.com/products.html
But I believe there are many other vendors out there.
Amit Shachaf
(3,674 Views)
