I just sarted using Vision assistant and when I want to do a sequence acquisition, the sequence acquisition wizard only shows the input of the number of frames only. How do I set the Skip Count?, Line, triggering action, timeout and polarity? I only have that one option of Number of frames and then have to click next and finish. Do I do these settings in Vission assistant?, if so, how? Or I have to set all this in MAX? am using labview 2013. If I get a time-out error do I set it in MAX as well? Could not acquire (ROI) whilst acquiring continous images. do I need to install some drivers or all this I set in MAX?
