07-05-2008 05:19 AM
07-07-2008 08:12 AM
07-07-2008 10:27 AM
07-08-2008 03:15 AM
08-09-2008 04:06 AM
Dear kumi,
Unfortunately NI USB driver is only supported in IMAQ Vision Assistant and LABVIEW. You won't be able to use it in VS.NET. You may resort to third party component that could capture the image, save it to the disk using timer and then read it in CWIMAQViewer
08-09-2008 07:03 AM
10-01-2008 08:43 AM
hi
thanks for the answers but the problem is this costs a lot of performance by saving and then reloading, i need the pattern mach and the snapshop made in less than 500ms
any ideas?
10-01-2008 08:35 PM
