Machine Vision
two monitor display application
In my application i need to create two monitor Display .
so in need two front panel display
is it possible to do
(4,824 Views)
In vi properties, window runtime position, set it to differecnt monitor.
(1,176 Views)
Perhaps this class will be useful for you:
https://github.com/keale/Viewable_Actor
It saves the last position and size of a vi and restores them after a restart.
It is designed to work in the context of the Actor Framework, but can also be used like a passive object.
(1,163 Views)
