05-09-2017 10:27 AM
Good evening, I have a medical project where i will use labview (vision NI-IMAQdx...) and USB video camera ,and i have a problem ,how can i get a succession of images that separate between them 3 or 5 seconds from a USB camera video,and after that i must to process this images,Please if can any one help me its urgent case.
Thank you.
05-09-2017 01:23 PM
05-09-2017 01:43 PM
I mean to take a picture each 5 seconds from the video acquiring directly from usb camera.and when you take this picture you can proceed it.did you understand?
05-10-2017 03:16 AM
check this it help you to solve your problem
05-10-2017 09:14 AM
I was able to test the VI on my computer and it worked well to the use case. I'd be careful because this is a simple example that does a great job in showing you that it is possible, but it is roughly based on the Producer Consumer Architecture so be mindful of just copy/pasting the code into your's.
@Hatef nice VI!
-Bear
05-10-2017 04:33 PM
