Machine Vision
tab control in VBAI
I have a question using the tab control in VBAI. In labview was able to navigate through the tabs using the tab key. However when used as UI for VBAI the tab control doesn’t seems to work. Attached you will see a VI I was testing. Please let me know your thoughts.
thanks
(3,948 Views)
never mind got it figured out
(3,945 Views)
Accepted by topic author gsajja
A control has to be selected first before the tabbing works apparently. Here is a slightly modified VI and an example. If nothing has the key focus, tab doesn't do anything.
Hope this helps,
Brad
(3,944 Views)
thanks brad!
(3,940 Views)
