Machine Vision
some parameters not working after building application
I am facing a problem with pattern matching code.
After building code to application exe, pattern match step stats failing, none of component passes the inspection.
please suggest something.
thanks,
Praveen
(3,539 Views)
Hi Praveen,
Are you referring to a particular example given as a resource with LabVIEW or available online? If it is a code you have developed yourself, it'll be better if you can give some more details about the same here.
Vaibhav.
(3,513 Views)
As suggested post your code. Most likely you would be feeding a wrong search area. Have you created this from vision assistant?
(3,499 Views)
