‎01-09-2010 06:44 AM
I am facing a problem with pattern matching code.
After building code to application exe, pattern match step stats failing, none of component passes the inspection.
please suggest something.
thanks,
Praveen
‎01-11-2010 01:38 PM
Hi Praveen,
Are you referring to a particular example given as a resource with LabVIEW or available online? If it is a code you have developed yourself, it'll be better if you can give some more details about the same here.
Vaibhav.
‎01-12-2010 01:59 AM
