ā04-04-2010 10:01 AM
I am pranita.i am tring to snap , grab the images using imaq snap.vi,imaq grap.vi .But the problem is these vis are not present in the pallete (according to manual they should present in image acquisition pallete which should be in vision pallete.)
But under vision pallete only 3 palletes ara available.(image management, image utility and one more). Is there any problem in installation.But i have checked the status in MAX.It is ok.the labview version with me is 7.1(is it necessary that it should be LabVIEW RT).iIam using CCD camera .Plz reply
ā04-05-2010 01:32 AM
ā08-12-2010 09:36 AM
I'm having the same issue, with LV 8.6, IMAQ 4.4 and IMAQ I/O 2.3.1
ā08-12-2010 03:40 PM
Re-installed IMAQ, that fixed it...
